Water On/off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2010, 03:15 PM   #1
replace water line pressure regulator? should the on/off valve be before or after?
Should the on/off valve be replace before or after the pressure regulator
The Goose is offline   Reply With Quote
Old 07-24-2010, 08:30 PM   #2
I would wnt the on/off before the pressure reducer so the water can be turned off if I needed to replace the regulator.
hayewe farm is offline   Reply With Quote
Old 07-24-2010, 09:15 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
For the On/Off valve use one of these:
water on/off valve-ball-valve.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Leaking T&P Valve on water heater secutanudu Plumbing 22 07-06-2010 05:02 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Water Shut-off Valve Relocation ClnlBrahm Plumbing 6 09-02-2008 12:59 AM
