Water Not Running In House Anywhere - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2009, 12:26 PM   #1
water not running in house anywhere
Help! Water not on in house. condo unit in building, neighbors have water, called city, no main breaks, newer construction, checked main valve, its on and water was running a few days ago no problems. ANY IDEAS?????????
dennist is offline   Reply With Quote
Old 02-19-2009, 01:19 PM   #2
Newbie Bill
Rewards Points: 522
Frozen pipes?
drtbk4ever is online now   Reply With Quote
Old 02-19-2009, 01:43 PM   #3
MasterPlumber
ironrange's Avatar
The city turn you off at the meter?
ironrange is offline   Reply With Quote
Old 02-19-2009, 03:41 PM   #4
Thank you for responding. I just discovered there is a pump that is not working that helps the water get to the 3 floors above. The water feeds into the building through a garage, then gets pumped to the above floors. The plug is dead. Might be a ground fault or fuse at panel, or bad pump. This is a great site, thanks for getting back to me so quick.....
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water well running dry? Proulx06 Plumbing 4 02-28-2008 09:17 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
