Water Meter Washer - Fiber Vs Rubber! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2013, 10:12 AM   #1
wak
Water Meter Washer - fiber vs rubber!
I was recently told that all new domestic water meters require a rubber washer at pipe coupling instead of a fiber washer. Is this correct? What was wrong with fiber washer - any regulations against using them?
wak is offline   Reply With Quote
Old 05-07-2013, 10:23 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 678
Occasionally when I call the water company to turn off the service I ask for extra gaskets. They always give me rubber.
Old 05-07-2013, 06:45 PM   #3
Rewards Points: 1,514
Why not just use the rubber washer and be done with it?
Somehow I never understood how fiber washers could last a long time. Fiber does not have much compressibility to conform to the pipe joint and achieve a good seal. It appears to me that fiber washers work in the first place by becoming soaked with water and swelling as a result. But then the water soaked fiber starts to rot.
Meanwhile rubber has much compressibility and is also nonporous.
Old 05-07-2013, 09:26 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
I always keep a few in the trucks always rubber we also get them from the water company. i would guess fiber should be ok ????
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-07-2013, 09:45 PM   #5
Rewards Points: 582
its like everything else times are changing they used fiber ..now they use rubber.....imo rubber is better...why because it dosen't get water logged..ben sr
Tags
water meter washer
Water Meter and Irrigation Control segal Plumbing 1 10-07-2012 06:45 AM
Connect Meter For Temporary Water To Trailer TheGriff Plumbing 11 09-11-2012 10:17 AM
Water Meter Out of Control cdeliopo Plumbing 16 01-08-2012 10:08 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
