Water Meter Missing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2011, 10:29 AM   #1
Still Learning
water meter missing
hey I have a question... how illegal is it for me to put a nipple where my meter used to be? what are the consequences?
thehvacguy is offline   Reply With Quote
Old 04-27-2011, 02:01 PM   #2
You can be fined for Theft of Service. Where I used to live (Toledo Ohio) the water department would estimate your water usage and the fine was $150 plus 3 times the water and sewer service bill.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
plumberinlaw (04-27-2011)
Old 04-28-2011, 01:56 AM   #3
Still Learning
o well thats not that bad... I was thinking it would be in the thousands plus jail time... Thats totally worth the risk
Old 04-28-2011, 06:32 AM   #4
Just call me Andrew
Rewards Points: 1,020
Are you seriously planning to steal from your water department and posting about it online? Not only is that dishonest, it's about the most idiotic thing i've seen on these forums in 2 years.
Andrew
secutanudu is offline   Reply With Quote
Old 04-28-2011, 07:08 AM   #5
Plumb or Die!
While you're at it, bypass the electrical and gas meters!
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
VIPlumber (04-28-2011)
Old 04-28-2011, 08:16 AM   #6
Household Handyman
Rewards Points: 1,408
"hvacguy" posted "where the water meter used to be" Now, is the water meter currently not there? OR--are you going to do what some of us are thinking: removing your current water meter and replacing it with a nipple? You'd have to be really ingenious in my area to do this: Our City uses a "special" fitting coming off of the water supply line that is not standard pipe threads, then an adapter to the water meter.
Old 04-28-2011, 08:57 AM   #7
Still Learning
well, this is what happens when your parents dont teach you the importance of budgeting and good credit. I couldnt pay my water bill and after turning my water back on several times they took my meter. im gonna pay my bill but im not going to work smelly cause I cant shower...
Old 04-28-2011, 09:13 AM   #8
fabrk8r
fabrk8r's Avatar
I'm totally subscribing to this thread...this is gonna be epic!
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-28-2011, 09:58 AM   #9
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
We [I work for a city] will turn off your water at the B-Box, and put a specially designed cap over it, so it cannot be accessed. We had one guy torch off the cap to turn his water back on, so we turned off the water and filled the b-box with gravel (vac truck cleared it when we needed to access it again). Besides the obvious fines, he also got a destruction of public property charge and a few other things.
hyunelan2 is offline   Reply With Quote
Old 04-28-2011, 10:04 AM   #10
Rewards Points: 264
well, this is what happens when your parents dont teach you.....
Oh, well its obviously not your fault then. Proceed with indecent behavior and complete lack of common sense.
Lets say you pull this off and get it to work; what are the Vegas odds you'll ever do the right thing and put the meter back on?
Paying the water bill is a problem but the fines associated with what you're proposing are no concern? I'd rather take the odds that you'll strip the fitting, break the joint, or flood the house. Think through the ramifications of this, I really doubt its worth it.
moneymgmt is offline   Reply With Quote
Old 04-28-2011, 10:16 AM   #11
Still Learning
Actually im not a complete dumbass. Who strips fittings? I paid my bill and the meter is back on. This is a credit issue not an issue of morals
Old 04-28-2011, 10:29 AM   #12
hose from the neighbors house
The older I get the better I was
Old 04-28-2011, 10:56 AM   #13
Just call me Andrew
I can't afford a new TV, so I'll just go steal one. Credit issue, not morals.
Andrew
The Following User Says Thank You to secutanudu For This Useful Post:
tpolk (04-28-2011)
Old 04-28-2011, 11:19 AM   #14
Still Learning
I can live without tv, but not water.
Old 04-28-2011, 11:22 AM   #15
Rewards Points: 3,130
Please. Tell me you're not a ignorant and low-class as you sound.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Private Water Meter? fauer Plumbing 9 12-20-2007 06:44 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
