Old 10-06-2012, 09:27 PM   #1
Water Meter and Irrigation Control
The other day, my neighbor suggested that I keep an eye on my water meter each month to ensure that I'm not being overbilled. Well, I went looking all over my front yard for my meter, looking for the same iron cover lableled "water meter" that virtually every house in my neighborhood seems to have in their front yards. Well, on a hunch, I popped open a big green plastic cover labeled "Irrigation Control" and to my suprise found the water meter inside that box about 8 inches below the ground. While I do have an inground sprinkler system, the water meter is all that appears in that box. It's like a box inside a box. There are rocks surrounding the meter box and absolutely nothing else in there. I wonder if the meter ended up too low below grade and they had to come up with a simple solution. Any ideas???? Thanks in advance.
segal is offline   Reply With Quote
Old 10-07-2012, 07:45 AM   #2
Originally Posted by segal View Post
... Well, on a hunch, I popped open a big green plastic cover labeled "Irrigation Control" and to my suprise found the water meter inside that box about 8 inches below the ground. While I do have an inground sprinkler system, the water meter is all that appears in that box. It's like a box inside a box. There are rocks surrounding the meter box and absolutely nothing else in there. I wonder if the meter ended up too low below grade and they had to come up with a simple solution. Any ideas???? Thanks in advance.
Probably.
Or maybe the previous homeowner regraded the land around the meter box and installed the "irrigation control" cover to match the new ground level.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Water Supply Connection for House and Irrigation jasontf Plumbing 1 06-02-2011 12:01 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 05:50 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 01:31 PM
irrigation plumbing at meter Mike in Arkansas Plumbing 19 09-14-2009 01:59 AM
Whoa, how much water can my irrigation system use??? J187 Landscaping & Lawn Care 19 11-10-2008 04:04 PM
