Water Meter Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2009, 08:51 PM   #1
Rewards Points: 874
Water Meter connection
Hi;
Can anyone tell me what type of connection the outflow side of the water meter (USA, NJ) is?
It looks like a union to me, but I'm not sure.
The supply is 3/4", so I'm fairly sure that the meter is 3/4".
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-17-2009, 09:16 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Originally Posted by KE2KB View Post
Hi;
FW
A little more info please such as
what are trying to do?
Upgrading service?
Adding sprinkler system?
Old 03-17-2009, 09:20 PM   #3
Rewards Points: 874
Upgrading service?
I need to replace a section of pipe between the meter and the rest of the system.
I replaced a lot of it on Saturday, but while inspecting for leaks in the meter closet, I found that the pipe going out from the meter to my new plumbing was pretty bad.
Today, I found that it is already starting to drip.
I can take a photo, but it's late now, so I'll do it tomorrow morning.
FW
Old 03-17-2009, 09:30 PM   #4
Rewards Points: 560
I'm sure how it is there but all that I have done where the fitting off the meter to the house is compression fitting. Where as there is a 3/4" 90deg fitting. then between the fitting there is a rubber washer and is coupled with a nut. Most water jurisdictions require a licensed plumber to make this connection and must have rigid pipe out of the meter can. Believe me when I tell you to check with you local water service provider. If you break anything in the meter can to include service to the meter it can get very EXPENSIVE.
Also depending on service requirements when the can was set fitting sizes may be different than 3/4"
Old 03-17-2009, 10:11 PM   #5
Rewards Points: 874
So, maybe I just won't touch the meter at all.
I could just replace from the first joint onwards. There is that old ball valve that I would like to replace, but if it's going to require hiring a licensed plumber, then I'll leave it alone too.
I hadn't thought much of damage to the meter. It seems to be a very solid can (as you call it).
I'll take another look at it tomorrow morning and decide how much I really need to replace.
Thanks for the advice
Edit: I looked up my township code, and found absolutely nothing about plumbing. If it's going to be an issue, it might be with the water utility, but not the township, as it appears to me.
This said, my 10yr old water heater does have a tag indicating that it passed plumbing inspection. Perhaps because it is a gas appliance?
Maybe I'm not looking deeply enough into the township code.
FW
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Water heater connection navysuit Plumbing 5 06-17-2008 09:52 PM
possible leak after water meter sharp1 Plumbing 2 03-20-2007 03:45 PM
