Water Meter - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2011, 12:02 PM   #1
water meter
I would like to convert a duplex from one water meter to two what will the cost be
beecee is offline   Reply With Quote
Old 02-24-2011, 01:15 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... Only your water provider can tell you that information...
And/ or the plumber you're asking for a bid....
Old 02-24-2011, 01:39 PM   #3
Rewards Points: 256
To convert to two water meters, you will need to seperate the supply lines totally, you might also be required to seperate the drain/waste/vent lines, but that depends where you live.
The short answer is: too much for it to be worth it, unless it's part of a major reno.
Note: I own two duplexes.
It really depends on how much plumbing there is in your place.
Another way to phrase the question is how much would it cost to rip out every piece of plumbing in the whole house and replace. A lot will depend on the quality/cost of labor.
I doubt you could get it done for under 5-10K.
michaelcherr is offline   Reply With Quote
The Following User Says Thank You to michaelcherr For This Useful Post:
beecee (02-26-2011)
Constant sound flowing water at meter tbeaulieu Plumbing 5 03-06-2010 08:44 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Private Water Meter? fauer Plumbing 9 12-20-2007 06:44 PM
