Water Main Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2013, 08:18 PM   #16
Rewards Points: 1,684
Originally Posted by SPS-1 View Post
My mother's house had a water supply with a gate valve before the meter, only. 1960 house, and the valve is surely original. Last time I had to shut it off, I added a ball valve after the meter. I was praying that when I shut off the gate valve, it would be tight enough to give me the time to solder in the ball valve. Ball valve soldered in fine. I will never touch that old gate valve again.
Good man...
Old 08-20-2013, 09:21 PM   #17
Rewards Points: 1,088
what would you do if the valve leaks and tightening the packing nut doesn't work?
handy man88 is offline   Reply With Quote
Old 08-20-2013, 09:45 PM   #18
Get your water provider to shut your house water off and replace your shutoff valve. Or you an just freeze the line before the valve and replace it then.
The Following User Says Thank You to Ghostmaker For This Useful Post:
plummen (08-22-2013)
Old 08-28-2013, 12:21 PM   #19
Rewards Points: 131
Originally Posted by Ghostmaker View Post
Your first valve in the house is usually a flare type valve. Then after your water meter you have a secondary valve.
Ghostmaker is right. My gate valve, which is also frozen open, is flared. I did not have enough space to cut off of the flare and put in a new ball valve so I just reused the old one for now until the basement reno.
HitLines is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 02:24 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
