Water Main Mystery Device - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2011, 09:27 AM   #1
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Hey, guys.
The water pressure in my townhouse has always been pretty weak. My neighbors do not have the same issue. Recently, I've been suspecting this...umm...thing. Where the water enters my house, this device sits between two gate valves. What is it? Do I need it? If it does have something to do w/ my low water pressure, is it adjustable/replaceable/removable?
That 'range' entry on the tag makes me think it's a pressure control device of some sort, but I am definitely well below 25.
Thanks!
inK
Hammer in Hand, Dad on Speed Dial
http://www.mydadsshoes.com
ink is offline   Reply With Quote
Old 04-21-2011, 09:32 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, but you're exactly right...that is a pressure control valve, normally installed to reduce public water pressure that is too high. It is adjustable. Loosen the nut on the right and turn the threaded rod up or down to increase or decrease the pressure to suit.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 04-21-2011, 10:10 AM   #3
It's called a pressure reducing valve (a.k.a. - PRV.)
VIPlumber is offline   Reply With Quote
Old 04-21-2011, 10:39 AM   #4
Just call me Andrew
Rewards Points: 1,020
It works backwards of how you might think...once you loosen the nut to make adjustment possible, tighten that rod to increase pressure, loosen the rod to decrease.
I'd get a pressure gauge, hook it to the outside hose spigot closest to the main, and slowly increase your pressure until you are at a more comfortable level, but definitely do not go over 70-80ish. 65 would probably be good.
Pressure gauges look like this:
Andrew
secutanudu is offline   Reply With Quote
Old 04-21-2011, 10:48 AM   #5
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Thanks everyone.
That probably saved me a lot of frustration later. Awesome.
~inK
inK
Tags
water pressure
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
5/8in water main linuxrunner Plumbing 4 02-02-2011 05:33 PM
Main drain water back ups destroyer427 Plumbing 7 04-07-2009 01:58 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
