Old 08-15-2011, 09:16 PM   #1
Water Main/Irrigation Main
The pipe that goes to irrigation system at main has failed. The joints attaching to the metal shutoff valve were leaking. Cut off the bottom pipe below the failing threads.
My questions are: do I have to replace the metal shutoff with metal - or can a pvc valve work? And, the top and bottom are rigid - what's the best bet for fitting pipe on here?
coyote_ptm is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
