Old 12-17-2007, 01:25 PM   #1
Water main Elbow at House
Hi! We had some type of grey pipe as our water main from the meter to the house when we bought it 2 yrs ago (30 yr old house). Over the last year we have had many leaks. We kept digging up and patching. The last one was under the driveway, so we finally got rid of the gray and replaced it with white PVC. We had to run an elbow from the house at a 90 degree angle then straight down to the water meter. We ran into a small problem. We couldn't get the gray off of the elbow at the copper pipe that runs into the house. We left a small piece of the gray and ran it from there.
Well now it keeps popping off and we don't know how to keep this on. We had a few estimates from the pros and we simply cannot afford any of them.
Any suggestions?
anagy007 is offline   Reply With Quote
Old 12-17-2007, 02:37 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Post a picture please.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 12-17-2007, 04:16 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,........... Pretty Simple actually,........
Cut Off the offending Fitting,+ Replace it with the proper 1..............
Old 12-17-2007, 04:26 PM   #4
RippySkippy's Avatar
Originally Posted by Bondo View Post
Ayuh
What does that mean?
RippySkippy is offline   Reply With Quote
Old 12-17-2007, 04:34 PM   #5
Bondo's Avatar
It's a word that usually means in agreement, or yes, or acknowledgment....
It's a local dielect from the eastern end of the coast of Maine, called Downeast........
Where My roots are,... Even if I'm Not there.....
Ayuh is also used as "Well" as you would say, Well,...... I just Donno..........:D
Btw,....... Phonics is Long A,+ short u.......
Whole House Water Treatment Systems HWPipes Plumbing 21 04-25-2013 09:53 PM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 11:36 AM
Main Water Line willyoldschool Plumbing 6 11-03-2006 08:01 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
