Old 01-10-2011, 09:42 AM   #1
Water main break yesterday - now toilet won't stop running
Our water main broke about a block away yesterday, and when the city had it all patched up, I had to run a good bit of water through all of the faucets to get clean and bubble-free water to flow. As soon as the water came back on, one of my new toilets just started running non-stop. It's not a heavy flow, just a constant hiss coming from the tank. Is there likely a piece of dirt that's holding something open in the tank innards?
It's a Kohler/Fluidmaster fill valve. Not really sure if/how to take it apart.
One thing I learned with this is that the plastic stem 47-turn stop valves that the big orange box sells are crap. If I have to empty the tank anyway, I'll probably go ahead and replace that with a quarter turn valve too.
spidrw is offline   Reply With Quote
Old 01-10-2011, 09:47 AM   #2
http://www.toiletology.com/troubles.shtml read #2 it gives a good description of disassembly for cleaning out debris
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
spidrw (01-10-2011)
Old 01-10-2011, 10:27 AM   #3
Perfect! That took care of it. Thanks.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Low Flush Toilet - Water Running ? GBunny Plumbing 1 10-09-2010 09:10 AM
Low Flush Toilet - Water Running ? GBunny Plumbing 2 10-09-2010 08:52 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
