Water Lines In Walls ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 03:51 PM   #1
water lines in walls ?
hello , we have water lines that had to be replaced a while
back. they couldn't run the lines under the house because
of our concrete foundation there is now space under the
house . so instead they put them through the walls next to
the ceiling were there seen running through the house .
do to a recent renovation we have the drywall took down
and it is possibly for us to run them inside the walls. but
i think ive heard this is a bad idea because if they were to leak
the walls will be ruined .
is this true should they never be ran on the inside of the walls ?
thx for the reply' s
rascae is offline   Reply With Quote
Old 07-16-2012, 04:15 PM   #2
Rewards Points: 14,026
Plumbings ran through walls all the time. I would suggest not runing them through outside walls or the attic if you live in an area where it ever freezes.
If it's new lines your trying to run then the best way is to use Pex tubing, that way you can make up to 100' runs with no joints behind the walls.
Old 07-16-2012, 04:34 PM   #3
thx for the quick response , we would need a couple joints they will be cold and hot lines to
the sink an shower . would we have to run the joints outside the wall then back in to the shower ?
srry for the noob question this is a new area for us.
Old 07-16-2012, 06:20 PM   #4
I think your going to have to call in a real plumber on this one judging by your questions.
Not trying to be mean.
Old 07-16-2012, 06:52 PM   #5
no prob , lol thx anyway .
Old 07-16-2012, 07:11 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I challenge your question with a question : If the water line is outside of the wall, and it leaks, what do you suppose will happen?
Journeyman Plumber
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
