Water Lines To Tub,washer,sink,and Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2011, 02:28 PM   #1
Water lines to tub,washer,sink,and toilet
I am adding the equivalent of a full bath plus washer and dryer to a garage area. Should I run 3/4" water line or will 1/2" Pex work for that?
ArtBraendel is offline   Reply With Quote
Old 04-19-2011, 05:17 PM   #2
Rewards Points: 410
If done with copper, you have to protect it from cement as copper & cement react and it's not a good thing.
Otherwise it's pretty easy. The reason there's rules to what you can use with copper is that copper degrades rapidly once water flows through it at a certain velocity which I think is 8 feet per minute it may be 15. Beyond that the water is flowing so fast through the pipe it starts to tear at the pipe and it doesn't last long so 1/2" pipe typically can supply 2 fixtures. 3/4" copper pipe can supply the needs to 4 fixtures (because it's volume is twice that of 1/2"). So you'd run 3/4" pipe to the bathroom and once at the bathroom tee off to 1/2" pipe with one run feeding 2 fixtures and the other run feeds the other 2 fixtures.
As for pex, I don't know if the rules apply or how fast water FPM can flow through it and not damage it.
Piedmont is offline   Reply With Quote
Old 04-19-2011, 05:22 PM   #3
Rewards Points: 129
1/2" pex is not equivilent to 1/2" copper. The inside diameter of 1/2" copper is actually more duplicated with 3/4" pex.
wease is offline   Reply With Quote
Old 04-19-2011, 05:37 PM   #4
Rewards Points: 410
Good point, I wonder if PEX suffers wear & tear at high velocities like copper, and can they get away with 3/4" PEX. I personally would go bigger than 3/4" PEX or at least 3/4" copper even if it's okay because of the washing machine. They typically have fast solenoid valves which instantly stops the water flowing to them. You take water flowing at high velocity and shut the valve off instantly and BANG... waterhammer as water can't stop on a dime (along with a lot of wear & tear on the piping). Make sure you put water hammer preventers on the lines near the washing machine (closer is better) and I like the ones that screw in as they don't last forever. Or, get a washing machine with a slow closing solenoid. Whatever you do, don't try to create the homemade water hammer preventer (extra piping with a cap that's "supposed" to hold air. It doesn't last long).
Old 04-20-2011, 02:55 AM   #5
Piping information
Hey thanks everyone for your input. I learned a lot from all the posts. I will run with 3/4 Pex till I get where it splits off to just two appliances, the sink and washer. I can run 1/2 inch from there.
Old 04-20-2011, 07:41 AM   #6
Plumb or Die!
Perfect.
plumber666 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
correct size pipe for water lines jce Plumbing 2 04-11-2010 09:23 PM
