Water Lines On Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2009, 06:14 PM   #1
toolbelt Tina's Avatar
water lines on slab
I have cpvc water lines on slab constrction in an upstate NY cottage.
There will be periods of freezing without any heat.
I was planning on adding fittings to the start of the run to blow out the lines with my 8 gallon compressor. I do my own irrigation lines (although it takes a few shots due to the small sized compressor .)
i was wondering how cold it would get at the level of the slab?
I have placed pipe insulation on the 3/4 lines. Should I put rigid foam under the pipe as well?
There is some slope to the lines. There are no pipes in the outside walls.
Should I insulate the inside walls where the 1/2 lines are supplied to the fixtures?
Will I be ok?
toolbelt Tina is offline   Reply With Quote
Old 05-19-2009, 08:09 AM   #2
Rewards Points: 150
Will I be ok?
If the temps will be below freezing the best thing you can do is get all the water out of the lines. It will be colder down on the slab than it will above it. If I remember right it gets pretty darn cold in upstate new york. You might consider putting some water pipe anti freeze in the lines(non Toxic) available at most of your rv supply stores. I am assuming of course that you won't be living there during that time and that you are winterizing the cottage for the winter. you can also use that anti freeze in your toilet tank and bowl and sink traps. get an anti freeze that is rated to at least -50 zero farenheit.
al's sewer is offline   Reply With Quote
Old 05-20-2009, 08:32 AM   #3
Agree
Totally agree with Al, I would get a 5 gallon bucket with a pump and use RV antifreeze and pump it into the lines and open each faucet until it came out and add to traps and toilets like Al said.
Water lines are tricky there could be low points where the water lays and freezes and if you use air it might not be enough pressure to blow all the water out.
With the antifreeze when you see it come out each faucet you know your covered.
SULTINI is offline   Reply With Quote
Old 05-20-2009, 07:29 PM   #4
thanks
thanks for the input; I was aware of antifreeze for the traps and toilet.
The cottage will be used in the winter about once a month but will not be heating it my absence.
I did however heat the utility room so I did not have to empty the hot water tank and pump.
Could I open up the first fixture and blow the air through then close that one and proceed down the line until all fixtures are complete?
Tina
Old 05-21-2009, 07:41 AM   #5
Rewards Points: 150
Tina
You might have to do them all several times but even then I wouldn;t guarentee you have gotten all the water out.
Old 05-21-2009, 03:14 PM   #6
Rewards Points: 1,910
Blowing with your compressor might result in compressor oil in your water lines unless you have a really good filter on your air line.
If you're going to use the cottage monthly it might make sense to keep it heated to say 45 -50.
Old 05-21-2009, 08:05 PM   #7
extra protection
electric heat baseboards. It will probably cheaper to fill with the antifreeze.
Thanks for the oil tip never considered that.
I am putting down rigid foam on the slab and then pipe insulation on the water lines. Insulating in between the studs as a precaution. Or will all the extras not matter?
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 02:36 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
plastic water supply lines macwall Plumbing 5 07-04-2008 08:43 AM
Attaching water lines to floor joists handyflyer Plumbing 8 04-30-2007 11:43 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
