Water Line From Well To House. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2013, 07:12 PM   #1
Water line from well to house.
Well is located 70' from house, has an installed pipe that is below frost line and comes into basement through outside wall. We want to build a sunroom that will be over part of the existing pipe from well to house. Is this a problem? I figured if we had a problem with that section of pipe we would have to run new lines anyway and could bring them into the basement about 7' from the present line. Am I missing something as we have the plans and construction will start soon. thanks
Dick33 is offline   Reply With Quote
Old 05-20-2013, 08:09 PM   #2
Rewards Points: 582
can't see what your looking at...but it sounds like you have it worked out ....go for it ben sr
Old 05-21-2013, 08:41 AM   #3
Rewards Points: 3,130
You should be fine (assuming you don't damage the line digging a post hole or something like that). In 40 years of owning homes, I've never had to replace a water line. Sewer line, yes (twice), but never a water line.
Old 05-21-2013, 09:08 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
is the water line below the depth of your footings or are you using pier construction?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
water main whine related to main sewer line? denemante Plumbing 4 03-07-2013 10:14 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 03:50 PM
Water supply line blackhemi Plumbing 4 04-09-2011 09:18 PM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 11:18 PM
