Water Line To Toilet Drips After Toilet Seal Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2010, 07:08 PM   #1
water line to toilet drips after toilet seal replacement
I replaced the "donut" in the toilet and after toilet re-seated and completed, I now have a drip in the basement coming off of the water line coming up through the floor to the toilet. The connection in the water line coming from the floor to the toilet drips where the connection is made to the short line in to the toilet. How do
I tighten or secure this connection to stop the leak?
J-lou is offline   Reply With Quote
Old 10-20-2010, 06:28 AM   #2
Not sure what you are describing. The usual connection is 1/2" pipe to a shutoff valve. Then 3/8 pipe with compression fittings from valve to toilet. If the pipe was rigid, replace with steel wrapped flex pipe. Those rigid pipes often don't seat in the same place after removal and can be a bear to reseat without leaks.
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 09:50 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
GE REfrigerator Water Line Replacement Tom the Amature Appliances 1 10-04-2009 07:19 AM
Water leaking from below new toilet C_J_GO Plumbing 12 09-27-2009 07:49 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
