Water Line To Shed Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2010, 08:28 PM   #1
water line to shed questions
location-central mi
job- run water line 100' from house to shed for wash sink
questions
1. what kind and size of pipe? i have copper throughout the house
2. do i have to go below 42" or can i stay higher and insulate the pipe?
3. estimated cost for materials, trencher if i have to go below 42".
thanks
jredwood301 is offline   Reply With Quote
Old 01-27-2010, 08:43 PM   #2
Insulation only keeps heat in
So unless you are going to run water all the time its useless
You would need to go down below the frost line
Old 01-27-2010, 09:03 PM   #3
Rewards Points: 150
We use black poly. 160 PSI. Most of the time 1 inch.
About 5 foot deep.
user69544 is offline   Reply With Quote
Old 01-27-2010, 11:48 PM   #4
Irrigation Contractor
Location: South Central British Columbia - The great White North
Driller 1 does it the exact same way that I do it also. You have to stay well below the frost line.
Is the shed heated?
If it's not, then it's not going to matter, because the water will freeze when you get to the sink. If that's the case you'll have to have a shut off and drain in a heated space in your home before it goes to the shed.
If that is the case you don't really need to stay below the frost line because you will be draining it every fall. Make sure that you don't 'belly' the pipe for proper drainage, or even better, have it blown out in the fall just like your irrigation system.
Mick
Water Guy is offline   Reply With Quote
Old 01-28-2010, 05:01 AM   #5
Too Short? Cut it Again!
Originally Posted by jredwood301 View Post
location-central mi
Could you please click on your log in and update a basic location for future posts please?
No matter the situation, I would put a cut-off at the house in case you were to nick the pipe in the future or something. It would be silly to have to have your water turned off while you chase a leak somewhere in a 100' length of buried pipe.
You just rinsing dirt off your hands or are you going to be rinsing solvents and things too? If the latter is the case, you will have to figure out how drain whatever sink you put in the shed.
Don't forgot to call your utility locating company before digging the trench!
Old 01-28-2010, 08:04 AM   #6
Rewards Points: 150
In Michigan just dial 811. This is for all public utilities.
Old 01-28-2010, 08:34 AM   #7
If for some reason you decide not to go below the frost line and shut it off every winter you should run non toxic antifreeze through it every winter. ( RV Antifreeze Pink stuff about 3.50 a gallon).
SULTINI is offline   Reply With Quote
Old 01-28-2010, 08:45 AM   #8
Rewards Points: 150
location-central mi
questions
thanks
Talk to your local health department about drainage.
Old 01-28-2010, 02:29 PM   #9
ANSWERS TO QUESTIONS.
#1 See post #3
# 2 See post #3
# 3 Just DIY site not set up for estimates, it's up to you to pick the type of tools used. Backhoe or trencher.
Old 01-28-2010, 05:02 PM   #10
thanks for all the replies!!!!!!!
but i do have one more question.
i honestly did not think about a drain what type of drain do you guys suggest??
minimal use of sink-washing hands
Old 01-28-2010, 05:29 PM   #11
Rewards Points: 150
Talk you your health department. It will be a contamination source.
http://www.cmdhd.org/
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Water shutoff questions robwallis Plumbing 1 02-09-2009 03:22 PM
Whole house water filter questions... epeterson777 Plumbing 7 10-12-2008 12:51 AM
