Water Line Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2012, 06:49 AM   #1
water line replacement
We may have to have our water line replaced from the meter to the house. What kind of pipe should it be replaced with?
Loretta
bubblegummom is offline   Reply With Quote
Old 03-10-2012, 07:57 AM   #2
DIY staff
Rewards Points: 7,174
Your location is needed----codes vary---what's best is not always what's allowed--so let us know where you live --and exactly where the meter is --most areas the meter is inside the house to protect it from freezing---so you see why we need more information----Mike----
plummen (03-19-2012)
Old 03-10-2012, 10:26 AM   #3
We're in Seattle and the meter is in the ground by the side of our driveway in the neighbor's parking strip. The pipe is probably under the driveway to complicate things. We have a leak and it's not obvious to us where it is. Just thinking ahead that the plumber may say the line needs to be replaced.
Old 03-10-2012, 10:58 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 542
You're options will probably be copper or poly. I'd go poly, its real common in my area. Also, if you have a plumber replace it, ask him if he can "pull" the line. The process involves threading a small cable through your existing line and attaching new pipe to it. As the cable is pulled back, along with the old pipe, the new pipe is pulled into position- very little digging and could save your driveway.
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
Homerepairguy (03-11-2012), LateralConcepts (03-16-2012), plummen (03-19-2012)
Old 03-10-2012, 08:49 PM   #5
Thank you, TheEplumber. Pulling the line would be great! I hadn't thought of that, hope he can do that.
By poly do you mean Pex?
Old 03-11-2012, 12:40 AM   #6
Plumber
Rewards Points: 542
Not PEX, it's polyethylene. I believe it's called 200# poly. It's the same pipe as used for irrigation but heavier.
Old 03-12-2012, 08:08 AM   #7
That must be what they call PE?
Old 03-12-2012, 12:47 PM   #8
So is there some kind of a meter that can detect a water leak? Is there a metal detector or something that can detect metal pipes?
Old 03-12-2012, 12:58 PM   #9
Plumber
Rewards Points: 542
Turn off the main shut off valve inside your house. Now look at your water meter dial. If the little triangle is spinning, you have a leak in your main before the valve.
There are leak detection devices and services. But they are only as good as the operator. IMO, usually not that accurate. And yes a metal detector will find steel pipe but not the leak.
How deep is your line?
Old 03-16-2012, 08:28 AM   #10
If we were to have a plastic pipe put in, how would the house be grounded?
Old 03-16-2012, 10:24 AM   #11
Rewards Points: 1,578
With grounding rods (8' long metal rods) usually 2 spaced 6' apart.
bob22 is offline   Reply With Quote
Old 03-16-2012, 02:14 PM   #12
Thank you! The electricians put those in when they gave us a new circuit breaker panel when our fuse box gave out a couple years ago. So I guess we're set.
Old 03-18-2012, 09:17 AM   #13
So we have had 3 plumbers come out and give estimates. One wants to use copper, 2 want to use pex. So now the choice. Several people have suggested HDPE, but that has not been offered.
But you know, we have moles in our yard from time to time and I have read that varmints chew through pex. What to do?
They would be using trenchless, directional boring equipment to go under the concrete.
Thank you!
Old 03-19-2012, 01:37 PM   #14
Epic Ninja
pipeninja's Avatar
Dude, if the waterline is already in... you shouldn't need to bore it. Just run a cable through the old pipe and pull the new line in place as you pull out the old one. We do it all the time! There's a video on our youtube channel of us pulling a waterline under a sidewalk and yard. Check it out from our site, Rochester Excavating
pipeninja is offline   Reply With Quote
Old 03-21-2012, 10:09 AM   #15
Thanks for the tip, PipeNinja, but they're going to put the new line in in a different place.
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 10:18 PM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 6 05-07-2009 03:27 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
