-   -   Water line for new refrigerator? (http://www.diychatroom.com/f7/water-line-new-refrigerator-3901/)
pa555 09-12-2006 07:58 PM
Hello everyone.
I need to run a water line for this new refrigerator with ice maker. My wife wants water & ice in the door.
My problem is there is no water on the wall with the refrigerator & house sits on a slab. So need to run up inside the wall into the attic, then down the inside of the wall behind the refrigerator. From cold water off washer (about 30 feet) or kitchen sink (about 20 feet) give or take. Then from the wall behind the refrigerator to the refrigerator itself.
Can I use 1/4" copper tubing for the run to the wall and to the refrigerator?
Or do I need to run 3/8" - 1/2" to the wall & 1/4" to the refrigerator?
I really don't want to solder if I can get away with it. Don't have the tools & hate asking to borrow tools.
What shut off valves should I use?
How should I tap into the cold water line? Not sure about those self tapping valves.
Looking for the easy way, but also less likely to leak.
Thanks for your time.
Paul
redline 09-12-2006 08:03 PM
Is there any possibilty that the line may freeze or will it always be in a heated space?
(or are you loceted in an area that doesn't get colder weather?)
Ron The Plumber 09-12-2006 08:07 PM
DO NOT USE SELFTAPPING NEEDLE VALVES, this are no good, replace the cold shut off valve under the sink with a duel shut off, two outlets, 3/8" and 1/4", then run the 1/4" water line to the fridge, and yes you can use copper for this.
pa555 09-12-2006 11:20 PM
1 Attachment(s)
Sorry should have told you I was in So. California so no chance it will freeze.
Thanks for the heads up on the self tapping valves.
After looking everything over I might try to run off the cold water line that was going to my hot water heater. Not sure why they capped it off & run the other pipe up into the attic, but the one they had capped does have cold water. I took the union off & turned the water back on to see if it was live & it was. By going from here somewhere would save me a lot of BS trying to run tube inside the wall to attic.
Do you think tapping in the line before the hot water heater would cause problems?
Paul
Ron The Plumber 09-13-2006 07:25 AM
Tap in on the right side, should be no problem, if anypart of that union is galvanized, get rid of it and use brass after the copper then put on the shut off vavle.
shellybellyb 06-08-2012 06:06 PM
ok, so, I used the self tapping water line (I know this thread says I shouldnt) but already did it....tapped into the cold water line for the washer. Ran the line from the washer thru the wall to the fridge. There is water, but very very low pressure. The ice trays only fill a little. THEN, when the washer runs....it stops at the rinse cycle now. Won't go further....any thoughts?
