Old 05-14-2009, 01:40 PM   #1
dtzulu
dtzulu's Avatar
water line joint leak
good afternoon,
my problem is this. the 3/4" water line from service to my water heater (hot water line) is leaking. the top part of the pipe is pvc, then the 2 nut, pvc connecter, and into the copper pipe that leads to my water heater. i purchased a new 3/4" X 3/4" coupling, followed the instructions, and turned back on the water from outside. i still have a leak at the top of the coupling where it is pvc. i took everything apart and reassembled it, making sure that everything was tight, but it still leaks. any advice?
dtzulu is offline   Reply With Quote
Old 05-14-2009, 07:14 PM   #2
HVAC / Plumbing
Are you using any compound on the threads ?? You'll just have to keep trying till you get it..There's Something you aren't doing right
kenmac is offline   Reply With Quote
Old 05-14-2009, 07:34 PM   #3
dtzulu
dtzulu's Avatar
first, thank you for taking the time to offer me some help. i'm using the qest qbc44 3/4X 3/4" coupling. i also asked the guy @ home depot should i use any type of sealant, both he and the instructions on the pack state that you should not use any type of sealant. i'm out there now trying to get it right. i hope this works, man i need a shower!! thanks again for the info...
Old 05-14-2009, 08:57 PM   #4
HVAC / Plumbing
If it's on the hot water side .. It needs to be rated for hot water. If it's got threads I use thread compound..
Old 05-14-2009, 10:18 PM   #5
dtzulu
dtzulu's Avatar
good evening,
i found out that my problem was that the pvc end of the pipe needed to be cut, once i did that then everything fit tight and when i turned the water back on... no leaks! thanks again, this is a GREAT site and i will be checking back..
david t
Blockage in kitchen water line. Local Yokel Plumbing 6 03-18-2009 11:34 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 09:51 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 06:34 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
