Old 05-27-2009, 09:14 PM   #1
Old fart still learning!
Default Water line "hums"
I replaced my gas hot water heater several months ago. Since then I have noticed a hum when I run the hot water. The wife says she can hear it sometimes when the cold is running but I can't. I have not been able to pinpoint where the sound is coming from because it seems to echo through the whole system. Water delivery is fine. Hmmmm.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 05-28-2009, 12:09 AM   #2
If you have a shut valve that you closed during installation, it may be a loose stem washer fluttering. If it is you will have to shut the water off pull the stem and replace the washer.
hayewe farm is offline   Reply With Quote
Old 05-28-2009, 08:04 PM   #3
Default Water line hum
It is humming because it don't know the words.
I'm sorry I couldn't resist it.
I'm not really a breaker.
SULTINI is offline   Reply With Quote
Old 05-28-2009, 08:21 PM   #4
Do you mean like a faucet in one of the sinks or something? I did have a couple open to bleed the line. Don't remember exactly when I closed them other than after bleeding the air from the line after filling the heater. This seems to happen when I run about every faucet.
This is something I had not even begun to suspect. Thanks.
Old 05-28-2009, 10:27 PM   #5
I mean an in-line shut off valve. They seldom get used and the seat washer deteriorates then when they are used the washer comes loose.
Old 05-31-2009, 06:25 PM   #6
HF
Now I'm on the same page with you. My apology for taking a few days to acknowledge your reply, been busy with a couple of other things. I'll try this as soon as I can.
Thanks.
Old 06-01-2009, 12:45 PM   #7
go in the basement when its humming and put hand on all the pipes to pinpoint the location,,,sometimes its just a 'loose' pipe!!
4just1don is offline   Reply With Quote
More On This Topic
Black walnut trees, used in landscape plans for their stately beauty and deep shade, grow in deep, fertile, well-drained soil and are tolerant of freezing weather conditions. Follow these steps to plant them. Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 03:02 PM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 7 05-07-2009 05:27 PM
My water line install to icemaker jrowny Plumbing 3 01-24-2009 04:32 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 10:09 AM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 07:34 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
