Water Line To Fridge Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2010, 08:20 PM   #16
thank you for that coldiron,
my saying 10' is me regurgitating max length( in my code) for the supply. and as you say to secure it to the fridge and wall is a great point, the water supply to a fridge is a scary connection because you cant see it. when installed with hardwood floor, by the time you recognize a leak its a couple thousand dollars to late.
Ltnicks is offline   Reply With Quote
Old 11-17-2010, 10:56 PM   #17
I purchased a 1/4" braided steel line that is made for fridges. It also has a auto shutoff on it that if for some reason it bursts it shuts off. My plumber is coming buy to re terminate the end of the pex so we can install the braided steel.
ingeborgdot is offline   Reply With Quote
Old 11-18-2010, 12:36 AM   #18
Homerepairguy's Avatar
Rewards Points: 990
STOP, HALT, DON'T INSTALL THAT BRAIDED LINE WITH AUTO SHUTOFF until you read this thread:
http://www.terrylove.com/forums/showthread.php?26673-Watts-Floodsafe-Not-Very!-part1#post183626
HRG
Homerepairguy is offline   Reply With Quote
Old 11-18-2010, 07:45 AM   #19
Okay, got it. My plumber has a standard 1/4" braided line to use. I will take the other one back.
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Removing Water Line Obstruction Mickey53 Plumbing 11 12-15-2009 12:39 PM
Water source from fridge from water heater? dankreboot Plumbing 11 07-12-2008 11:08 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
