#1 |
water line connections to valves
i quess my question is probably a simple fix for some but, i am a real newbie to plumbling i can solder copper and run vents set shower pans etc. although when it comes to hooking it all together iam kinda lost.what iam trying to do is turn a garage into a play room with a bathroom, this means i have to run the drains to the house and try to get my water from the house. i have all the copper put together,coming from the house what is the best method to get hot and cold lines to the garage? and what type of line ? hope this isnt to vage. thanks
Last edited by mike preston; 03-30-2011 at 01:38 AM. Reason: hard to explain the situation |
#2 |
Welcome! Name, rank, and serial number are not required here, but... a little more information would be good.
#3 |
Mike, I am probably not the guy to answer your questions, so just trying to help you get some helpful information posted, so... Is this an attached garage? If so, would you be coming through a wall, from a basement, etc? If not, what is the distance from the house to the garage? Where are you located, or, more specifically, is feezing a concern? I assume not if it will become a play room, but what about the runs in between? How far are you from existing supply lines, waste lines, and vent stacks? Again, I probably will not be the guy to answer some of your specific questions, but just trying to help you get some details posted, in order for someone to be able to provide some input.
| Display Modes | |
| Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge | huuuss | Plumbing | 24 | 12-11-2011 10:03 PM |
| Water leak, over 1 gallon every 5 minutes. | carl1864 | Plumbing | 13 | 01-15-2010 01:31 PM |
| How to Install a Water Line to a Refrigerator With No sink | yerac2003 | Plumbing | 6 | 05-07-2009 04:27 PM |
| Testing 12 year old hot water expansion tank? | DJfixer | Plumbing | 2 | 01-01-2009 09:09 AM |
| Filling a Cast Iron radiator system | insulatorpro | HVAC | 7 | 10-07-2008 12:31 AM |
