Water Line For Addition - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2011, 04:51 PM   #1
Question
Water line for addition
Hi! For the addition I'm planning on the back of my home, I'm wondering if it would be a good idea to connect a new pipe to the main service line just after the meter at the curb and route that new pipe around the side of my home to the back where the addition would be built. My home is on a slab so getting to the existing plumbing would seem to be difficult.
I do have a line to a hose bib in back that I could use, however, that alone probably will not provide the flow needed for 2 complete bathrooms in the addition.
Also, a few months ago, I had a costly slab leak...hot water pipe leaked under the concrete slab apparently due to electrolysis after the water heater... so the remaining pipe may be a "ticking time bomb". If another leak under the slab happens again, I want to re-pipe as much of the house as I can using new Pex piping to avoid the potential for future leaks. I'm thinking that if I route the proposed new pipe from just after the meter going to the back of the house, that I would use that new pipe to do most of the re-piping.
Does this plan make sense? Are there any points I should consider in making this decision? Thanks.
woody9911 is offline   Reply With Quote
Old 01-19-2011, 08:44 PM   #2
The hose bibb would not supply enough water for even one bathroom so thats a no go. Hook on to the service line past the meter and run a new line to the back of the house. I suggest pvc but i dont know where you are. probably would be best to repipe the house from the new line and cap off the old service line in the yard when that time comes. Do it at the same time as the addition when the house is already under construction. its a big mess, sheetrock patches everywhere. Usually other than the cost and nuisance its not very hard
plumber jon is offline   Reply With Quote
Old 01-19-2011, 10:34 PM   #3
I'm in north Texas...city of Plano. I am thinking about using PVC. It may be over-kill but I'm thinking about using schedule 80 PVC to the house, then up through the new foundation into the attic. At that point, I would use Pex except for some copper for the leads from the water heater.
It doesn't freeze in the attic, but I would insulate everything.
Do you think using Sch 80 PVC makes sense or am I unnecessarily reducing water flow from the increased pipe wall thickness (compared to Sch 40)?
Tags
addition , main water line , pex
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
water line joint leak dtzulu Plumbing 4 05-14-2009 10:18 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
