Water Line Access Preference - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2014, 08:28 PM   #1
Rewards Points: 30
water line access preference
Hello. I am going to extend our outside water supply via PEX to our deck so we don't have to cart water from the kitchen to water over 40 tomato, pepper and herb plants. I will put a drain on this line and flush it in the fall and leave it empty during the winter.
I want to use a tee from the existing spigot... well from the pipe that feeds the existing spigot. Put the spigot back on the tee and run PEX up with a turn off; then run about 50' of PEX hiding it under the deck to three outside vantage points. My question is would you access the water line from the outside by taking off the beadboard skirting or take down interior cedar paneling? I know the main water line is located along the ledger inside the heated basement. The house was built in 1902 and I'm not sure why it is located there. I am hoping that the simple removal of the t/g beaded skirting will expose the pipe that feeds the spigot. Then I can connect to the pipe. We updated the main line in 1973 to copper from the street. And I don't remember if it extended to the spigot, which I hope is the newer copper and not the old iron. Do plumbers take off exterior siding rather than work inside on finished walls? Many of our walls are wallpapered, so fixing isn't easy... and it is lath and plaster not sheet rock. Tips on dealing with older homes and this situation are welcomed.
I will be working on a rental's water line at the same time and it is ca1930 so both are old. Figuring out a procedure for how to deal with replacing old iron pipes is my major focus.
Thank you in advance.
KathrynCecelia is offline   Reply With Quote
Old 07-12-2014, 08:29 AM   #2
DIY staff
Rewards Points: 7,174
If that old spigot is on the original galvanized piping---expect some problems--at that age unscrewing it might cause the threads to collapse-
Is there a safer place to tap into the cold line --in the basement--???
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
