Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2012, 08:56 AM   #1
water line
how to find a underground main water line from a house
marie drossart is offline   Reply With Quote
Old 08-14-2012, 09:19 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
easiest way is to go underneath the house and find out where the line comes into the house (usually on the same side of the house as the water meter is located)
Then go outside and make an educated guess, now that you know point A and point B
Journeyman Plumber
Old 08-14-2012, 09:58 AM   #3
Rewards Points: 3,130
"Educated guess" is right. I used to live in Richland, WA, the city built by the government in 1943 for the workers at the Hanford nuclear reservation. The government provided all utilities, and none were metered. Some time after the city was turned over to civilian control in 1958, water and electric meters were installed. Mine was, as is typical, in the front of the house near the sidewalk. But the water line looped all the way around the house and entered at the back.
Old 08-14-2012, 10:31 AM   #4
Rewards Points: 13,978
What's it made of? If it's old steel lines a metal detector works.
Your local heath dept. may even have it on file if the house is less then 20 years old.
If it's Plastic I've seen dousers find them.
One of my old employees would take a metal coat hanger, cut it in 1/2 and find power, water and gas lines.
Old 08-14-2012, 01:05 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Do you want to find it or avoid it?
http://www.call811.com/about-us/default.aspx
http://www.call811.com/state-specific.aspx
Old 08-14-2012, 01:16 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 802
Originally Posted by Blondesense View Post
I find these folks won't mark water on home owners property unless it has a tracer wire. And they usually don't.
But you need to call them regardless.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
