-   -   water line (http://www.diychatroom.com/f7/water-line-153649/)
marie drossart 08-14-2012 08:56 AM
water line
how to find a underground main water line from a house
Alan 08-14-2012 09:19 AM
easiest way is to go underneath the house and find out where the line comes into the house (usually on the same side of the house as the water meter is located)
Then go outside and make an educated guess, now that you know point A and point B
md2lgyk 08-14-2012 09:58 AM
"Educated guess" is right. I used to live in Richland, WA, the city built by the government in 1943 for the workers at the Hanford nuclear reservation. The government provided all utilities, and none were metered. Some time after the city was turned over to civilian control in 1958, water and electric meters were installed. Mine was, as is typical, in the front of the house near the sidewalk. But the water line looped all the way around the house and entered at the back.
joecaption 08-14-2012 10:31 AM
What's it made of? If it's old steel lines a metal detector works.
Your local heath dept. may even have it on file if the house is less then 20 years old.
If it's Plastic I've seen dousers find them.
One of my old employees would take a metal coat hanger, cut it in 1/2 and find power, water and gas lines.
Blondesense 08-14-2012 01:05 PM
Do you want to find it or avoid it?
http://www.call811.com/about-us/default.aspx
http://www.call811.com/state-specific.aspx
TheEplumber 08-14-2012 01:16 PM
199 Attachment(s)
Originally Posted by Blondesense (Post 988427)
I find these folks won't mark water on home owners property unless it has a tracer wire. And they usually don't.
But you need to call them regardless.
