Old 09-12-2011, 08:18 AM   #1
water level in toilet drops when another toilet is flushed
I just installed a new toilet in my hall bath the new toilet works fine but when it gets flushed the water level in the master bath toilet bowel drops
target1911 is offline   Reply With Quote
Old 09-12-2011, 09:36 AM   #2
Lightfoot's Avatar
sounds like it could be a vent problem.
Lightfoot is offline   Reply With Quote
Old 09-12-2011, 09:48 AM   #3
Never had that problem before should mention that toilets are back to back and only affects toilet in master bath
Old 09-12-2011, 09:56 AM   #4
Experienced
Jackofall1's Avatar
You could look at it this way......you are getting (2) flushes for the price of one......
You have a vent issue, the water leaving the new pot is causing suction on the Master pot, this a real good indication that the new pot is not tied to the vent correctly.
Mark
Old 09-12-2011, 10:19 AM   #5
This was a simple toilet swap old one out new one in .the new one is an american standard 888545 clean power dual flush wonder of that makes a difference
Old 09-12-2011, 10:21 AM   #6
Doing it myself
Alan's Avatar
So it wasn't doing that before?
Journeyman Plumber
Old 09-12-2011, 10:26 AM   #7
Nope not at all
Old 09-12-2011, 10:29 AM   #8
Doing it myself
Alan's Avatar
What kind of toilet was in there before?
Journeyman Plumber
Old 09-12-2011, 10:30 AM   #9
Experienced
Jackofall1's Avatar
It would make a difference if the old pot had a much smaller flush valve (size of the exit orfice) than the new one. Your new one is moving liquid faster than your old pot.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
target1911 (09-12-2011)
Old 09-12-2011, 10:45 AM   #10
Old toilet is 14 yo standard construction grade toilet just never see this before thanks
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
water level in toilet toolbelt Tina Plumbing 8 05-30-2009 06:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
water on floor around toilet learnin' Plumbing 6 11-16-2008 08:18 AM
