Water Leaks From Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2010, 07:47 PM   #1
water leaks from vent pipe
I have been having plumbing issues with my kitchen sink,i have a dishwasher and a garbage disposal hooked to it.Well my sink every couple of months gets backed up.well i usually block one side of the sink off and turn the garbage disposal on with hot water for a few minutes and it usually starts to flow again,but this time water is leaking out the vent pipe and the drain is still backing up.What do i do now?
jasonmein is offline   Reply With Quote
Old 12-03-2010, 08:39 PM   #2
Rewards Points: 150
Leaking out the Vent pipe???
First repair the spot it is leaking out the vent pipe unless you are talking about a Studor vent.
Hot water and the garbage disposal is my first step second is a snake you can get from a big box store that attaches to a drill... You can also get it cheaper at Harbor Freight and for the occasional use it is fine. You need to figure out what is causing the leak... Is it Grease or are you putting the wrong thing in the Disposal. Depending how far you are to the main from your kitchen you can wrap a rag around the tip to force what ever it is into the main.
Docwhitley is offline   Reply With Quote
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Can range hood and water heater vent share same roof vent? huynh HVAC 3 09-08-2010 03:56 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Change in pipe diameter at water heater blacksheiladog Plumbing 2 03-06-2009 12:12 PM
Gas vent pipe getting water into it jwk937@hotmail.com General DIY Discussions 2 01-06-2009 05:47 PM
