Water Leaking On Bottom Of Faucet When Turned On - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2013, 12:12 PM   #1
Water leaking on bottom of faucet when turned on
Hi, my mom recently bought a condo and I am trying to learn as I go along. Recently the bottom of my faucet starting leaking. It only happens when I turn the cold water on. Do anyone know what is causing this? It is a sterling faucet
The red arrow is where the leak is coming over
Water leaking on bottom of faucet when turned on-main-leak.jpg   Water leaking on bottom of faucet when turned on-sink.jpg   Water leaking on bottom of faucet when turned on-bottom.jpg
SadPanda86 is offline   Reply With Quote
Old 02-17-2013, 03:21 PM   #2
Plumber & Gasfitter
Rewards Points: 77
If you are sure there is no water from above sneaking back in under the faucet then the supply stem just upstream of the aerator is probably cracked... New faucet time.
joeplumber85 is offline   Reply With Quote
Old 02-17-2013, 03:31 PM   #3
Rewards Points: 13,446
Or one of the stems is leaking and running down inside the housing so it only looks like it's leaking in the middle.
Should be able remove the handes to take a look at where the stem packing is. Often times a simple snugging of the packing nut will fix it.
Old 02-18-2013, 10:35 AM   #4
So I replaced the faucet stem and seat but the problem still persist. Does this mean that the whole faucet would need to be replaced?
Old 02-18-2013, 10:49 AM   #5
Plumber & Gasfitter
Rewards Points: 77
Sounds like a plan.
Old 02-27-2013, 09:30 AM   #6
sorry for the delay with update, so I have decided to get a new faucet. Do I need to get new water supply line or get I just switch the faucet and keep the old lines?
Old 02-27-2013, 10:18 AM   #7
Roofmaster
Rewards Points: 2,172
Remove and clean out trap, Close valves. Undo nuts at valves (5/8") and Pull off sink. place some cardboard and a couple of towels on counter and replace fixture, install new lines, then reset sink on hanger.
I would Replace the lines and the supply valves with 1/4 turn RA valves if you can solder. Also Escutchens. Then you wont have to worry for a while. I recommend Delta Fixture, Moen or Kohler, Delta is inexpensive and easy for homeowners. Make sure to get plumbers putty, and cover bottom of black plastic before setting fixture.
Replace trap washers and nuts.
Old 02-27-2013, 11:20 AM   #8
New faucet and supply lines should do it. Like mentioned above, go with moen they have great service/waranty.
jmon is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Anti Siphon faucet spewing water cai Plumbing 1 08-01-2011 02:48 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
