Water Leaking From Bath Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2017, 07:01 PM   #1
Rewards Points: 12
Water leaking from bath faucet
Video of issue is in the next post due to forum rules.
It was originally leaking from the hot, but I moved it over to the cold so I wouldn't burn my hand using the shower. I repacked the stem with some of that graphite packing material. It definitely helped, but didn't stop the leak altogether. It's possible my packing technique is lacking. I basically just jammed a lot of the material in there and tightened everything down.
Do I need a new stem, or perhaps a different packing material/technique? If I need a new stem, anyone know what brand this is? It's 4 5/16" long and 16 spline.
exacta is offline   Reply With Quote
Old 02-18-2017, 07:03 PM   #2
Rewards Points: 12
Re: Water leaking from bath faucet
youtube dot com /watch?v=d-S4rKT_Xnw&feature=youtu.be
Old 02-18-2017, 07:04 PM   #3
Rewards Points: 12
Old 02-18-2017, 07:06 PM   #4
Rewards Points: 12
Old 02-18-2017, 08:19 PM   #5
Rewards Points: 320
In your picture, it looks like the flat washer is nonexistent. Could just be the way I'm looking at the pic. Did you put a new washer on the stem bottom of the stem?
jmon is offline   Reply With Quote
Old 02-18-2017, 08:22 PM   #6
Rewards Points: 320
I don't recognize the stem type. Someone here might though.
You can take that stem to a local hardware, plumbing or big box store and try to match it up. I have good luck with a local hardware store.
Old 02-18-2017, 08:46 PM   #7
Rewards Points: 12
No matches at Home Depot. Scoured the internet all day and could not find anything.
Do think I might have luck trying to repack?
Old 02-18-2017, 09:01 PM   #8
Rewards Points: 320
Is there a new rubber washer on the bottom of the stem? it looks like the screw head is showing.
Old 02-18-2017, 09:03 PM   #9
Rewards Points: 12
Yes I replaced the washer. That is a screw head, but that's how it is designed.
The Following User Says Thank You to exacta For This Useful Post:
jmon (02-18-2017)
Old 02-18-2017, 09:39 PM   #10
Rewards Points: 320
You can try to repack again, but it didn't work the first time. Sounds like the stem itself or seats are bad. Its not getting a good seat. I'm leaning towards the stem. It doesn't work in either hot or cold.
Have you tried taking it to a plumbing supply or hardware store to match it up. Talk to one of the sales people to help you out they are usually retired plumbers. It's better than trying to scour the internet. You might get lucky. Just a suggestion.
Old 02-18-2017, 11:16 PM   #11
hkstroud's Avatar
Rewards Points: 2,048
The leak in the video is caused by the packing or the lack of packing around the stem.
Describe how you did the repacking.
Basically it should be
Remove the bonnet nut.
Wrap the stem with several wraps of string graphite. Push bonnet nut up to push graphite in. Tighten bonnet nut. Loosen bonnet nut and look to see if you can add any more graphite and still get bonnet nut to start threading.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 02-19-2017, 07:44 AM   #12
Mark Potter's Avatar
Rewards Points: 150
Home depot usually carriers seat washers that sits in the end with the screw thet holds washer down. This is what 90% of the time will cause water to pass by.
Mark Potter is offline   Reply With Quote
Old 02-19-2017, 08:24 AM   #13
hkstroud's Avatar
That is not the problem.
The problem is the leak around the stem.
The problem is exacta's lack of skill in repacking the graphite around the stem.
Harold,
Old 02-20-2017, 05:13 AM   #14
Well maintained boiler will function more efficiently and ensure that your family is safe from potential hazards. Thanks
evelynmin is offline   Reply With Quote
Old 02-20-2017, 09:11 AM   #15
Rewards Points: 1,668
Not sure I follow?
bob22 is offline   Reply With Quote
no hot water at kitchen faucet....all others are fine. ideas? tarheelblue Plumbing 10 12-28-2014 11:55 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
