Water Leaking Around Wellhead - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2012, 02:54 PM   #16
Amateuralex's Avatar
Rewards Points: 270
Originally Posted by countrygal View Post
The professional came out and replaced the plastic connector that I was unable to loosen. He essentially broke it off at the well casing then used a torch to melt it enough to get the rest of it out. Replaced it with a stainless nipple, reconnected the pipe and I now have water again. Cost me $170. I guess it would have been much more if he had to do the digging! I hope I'm good for another 30 years. Thank you all very much for talking me through this. Very helpful to know I am not alone in cursing pitless well systems.
Not bad, coulda been way worse.
Amateuralex is offline   Reply With Quote
Old 09-18-2012, 08:33 AM   #17
I thought you guys would want to know that my well started leaking immediately after my next door neighbor had a geothermal system installed. The well of the neighbor on the other side of the geothermal house also started leaking. For a while, we thought it was just a particularly wet spell and the ground was saturated. It wasn't until the well was leaking during a dry spell (and all of the plants around the well head were growing like wild fire!), that I realized that something was wrong with the well. Could the installation of the geothermal system have caused underground vibrations that cracked that plastic connector on my well? We are in a very rocky area. I would not try to get restitution from the neighbor. I am just curious.
countrygal is offline   Reply With Quote
Old 09-18-2012, 08:51 AM   #18
joed's Avatar
Rewards Points: 11,534
Anything is possible. I never use those plastic connectors for the poly pipe. I can never get them to seal properly. Always use the metal ones.
Old 09-18-2012, 09:14 AM   #19
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I suppose a well being drilled near yours could have caused a problem, but no way to prove. Frankly I was surprised that your pitless adapter is plastic, the ones I have seen were solid brass.
edit:
After reading Joed's post I realized you were talking about the barb insert fitting not the pitless adapter itself. Your well man replacing with a metal one did well by you.
Coastal South Carolina
Tags
well pipe
Main Water Shutoff Valve Inside leaking kentifur Plumbing 6 11-03-2011 08:16 AM
Main hot water pipe leaking under slab tiredofleaks Plumbing 9 09-12-2011 03:45 PM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 09:29 PM
First time homeowner from MD - Water Leaking from Ceiling under bathroom j_cross Plumbing 2 02-27-2010 12:37 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
