Water Leak From A Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2013, 09:36 PM   #1
Water leak from a valve
I found water is leaking from an very old rusty valve, it's a washing machine used valve, see the link to the picture, the leaking is from underneath the blue switch in the middle:
http://www.homedepot.com/p/t/202369988
Is there any chemical can stop this kind of leaking or I have to replace it all? The whole pipe system are very old, I'm afraid I will break other valves when turn them on and off while I replace this valve.
Qiqiangzhu is offline   Reply With Quote
Old 04-10-2013, 09:39 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Needs to be replaced.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-10-2013, 10:03 PM   #3
those can be rebuilt if you can get the repair kit. just a few o-rings
Old 04-10-2013, 10:06 PM   #4
You mean change those black rubber rings inside?
I still need to unmount it from the pipe, right?
Will those strong epoxy stuff work for this kind of leak?
Old 04-10-2013, 10:21 PM   #5
Always learning...
fetzer85's Avatar
Rewards Points: 262
You don't even want to try to epoxy it - that's like putting a bandaid on a gunshot wound. Either rebuild or replace as suggested. I understand what you're saying about possibly finding/causing other problems while making the repair but guess what? If you find them, fix them, easy as that. :-)
fetzer85 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Main Water Shutoff Valve leak & question leemort Plumbing 50 02-12-2012 07:25 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
