Water Leak Near Bathroom Entrance - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2012, 09:40 AM   #1
water leak near bathroom entrance
need to locate source of water leak. have already checked for leaks on commodes, bathroom & kitchen sinks, laundry room and exterior water spouts & no leaks detected. The leak is in the master bedroom.
rmom@fa is offline   Reply With Quote
Old 11-25-2012, 11:12 AM   #2
Rewards Points: 13,694
Leaking tub drain, stems on the handles to the bathtub leaking.
The seal around the waste stacks on the roof weather cracked and need replacing.
Old 11-25-2012, 11:33 AM   #3
DIY staff
Rewards Points: 7,174
You may have a bad seal on the toilet and water is traveling under the flooring---common problem---
Any sign of leaking below?
What is the floor covering?
Water condensation or external leak in newbieguy Building & Construction 25 06-23-2012 12:39 AM
Water leak in bathroom; no known source timtrice Plumbing 10 03-17-2012 10:00 PM
kitchen water leak! joregon3597 Plumbing 4 03-16-2012 02:45 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
