Closed Thread
Old 02-26-2012, 02:20 PM   #16
Doing it myself
Alan's Avatar
Water Leak Help!! 911
Did you flush the lines out before you put new valves in? Maybe something got stuck in one of them.
I love helping angry people.
Journeyman Plumber
Alan is offline
Old 02-26-2012, 02:21 PM   #17
are they all leaking or all in one zone or just one head
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline
Old 02-26-2012, 02:23 PM   #18
mkpr56's Avatar
Lines were flushed, it seems to be 2 zones head that are leaking!
mkpr56 is offline
Old 02-26-2012, 02:26 PM   #19
ok 2 zones and all off there heads leak in those 2 zones is this correct
Old 02-26-2012, 02:31 PM   #20
Doing it myself
Alan's Avatar
If the heads are still running, and the power is off to the solenoid valves, they should be SHUT. If they are not SHUT, something is stuck in them, or they are not working properly.
Journeyman Plumber
Alan is offline
Old 02-26-2012, 02:34 PM   #21
sounds like alan knows more than me keep educating me alan please
Old 02-26-2012, 02:37 PM   #22
mkpr56's Avatar
Yes all heads leak in those zones!
I find it hard to believe that I bought two bad valves, but could be the case I guess!
mkpr56 is offline
Old 02-26-2012, 02:38 PM   #23
Doing it myself
Alan's Avatar
Never worked on someone's sprinkler system before. Just using what I know about solenoid valves to get this guy to mellow out and quit being such a rude dog.
Journeyman Plumber
Alan is offline
Old 02-26-2012, 02:39 PM   #24
Doing it myself
Alan's Avatar
I doubt you bought two bad valves. There's something probably stuck in them. Pull them apart again, and flush those two valves for a good 3-5 minutes. If you keep getting crud coming out, then keep flushing until it runs clean.
Journeyman Plumber
Alan is offline
Old 02-26-2012, 02:43 PM   #25
test and make sure there is no power at valves also maybe something wrong with controller
Old 02-26-2012, 02:45 PM   #26
Doing it myself
Alan's Avatar
I'm sorry I seem to have offended you Alan! I was rude with the one jerk! Wasn't aware I was rude from that point on! I will try your suggestion! Flush again for 5 min! I'm on it!
I'm rubber you're glue : Please read this thread.
http://www.diychatroom.com/f36/announcements/
Good point above. Check to make sure the two solenoids that aren't closing, are receiving power. My guess is that if you slowed the leak by changing the valves, they have power, something is just hung up in there. Nonetheless, still a good idea to check for power.
Journeyman Plumber
Alan is offline
Old 02-26-2012, 02:48 PM   #27
An old Tradesmen
Rudeness toward anyone is not needed.
Some post have been removed.
beenthere is online now
Old 02-26-2012, 02:49 PM   #28
or not recieving power something i learned earlier so it will be closed
Old 02-26-2012, 02:52 PM   #29
mkpr56's Avatar
Thanks for the reading material Alan! Maybe you should read it yourself! To me it sounds like you need some re education,carrying on and being rude like you are! Thanks for all your tips!
mkpr56 is offline
Closed Thread
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 12:36 PM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 10:06 PM
No water in house dls6w4 Plumbing 10 02-12-2011 07:45 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Water Leak swoop Plumbing 2 01-14-2010 07:02 PM
