Water Leak From The Cap Of PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2010, 09:45 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 904
Originally Posted by orchid View Post
I just measured it: 2" ID and 2-3/8" OD.
this is a typical size of vent for a bathroom or sump. Its best to cap it. don't leave it open.
Is all the rough in work completed in your basement?
Old 09-19-2010, 09:02 AM   #17
If the water is coming from the cap, and no sign of water on the outside of the pipe, I still think it is condensation. Temperatures vary from your basement and the attic. Vent pipes have fumes and moisture in them. I am guessing the pipe is a vent for future use. It may have enough condensation in it to force water out of a bad glue job. being a vent (if it truly is) the installer probably didn't consider any water would collect and was just trying to stop sewer gas from entering the house.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-19-2010, 09:13 AM   #18
Thanks for the explaination. Am I better off leaving the cap off or do you think I still need it for keeping the sewer gas out?
orchid is offline   Reply With Quote
Old 09-19-2010, 03:39 PM   #19
Got it. The job is done. Thanks everyone for the big help.
Old 09-19-2010, 05:52 PM   #20
Rewards Points: 150
I really don't know. All I see is a PVC pipe sticking out from the basement ceiling with a cap on. Does anybody know the answer?
Help! majakdragon!
The answer is the vent may be tied into another vent or it goes to the roof; if it goes to the roof you would have water dripping every time it rained, if it tied into another vent you could have sewer gas comming thru it.
braindead is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 04:50 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
PEX pipe and sharkbite slowing water flow? Snav Plumbing 1 04-09-2010 03:32 PM
