Water Leak From The Cap Of PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2010, 02:51 PM   #1
water leak from the cap of PVC pipe
What's the purpose of a caped pvc pipe sticking out from the basement ceiling? I just noticed that there is slow water leak from the cap. It was raining. Does the rain have anything to do with it?
orchid is offline   Reply With Quote
Old 09-18-2010, 03:25 PM   #2
HVAC / Plumbing
Future water line to ???? Raining wouldn't have anything to do with it unless you have a leak that will let rain water in
kenmac is offline   Reply With Quote
Old 09-18-2010, 03:53 PM   #3
Rewards Points: 1,440
The cap might not have been glued on properly.
Old 09-18-2010, 06:28 PM   #4
Thanks, Kenmac and Allan. Any suggestions on how I may fix this?
Old 09-18-2010, 06:40 PM   #5
Rewards Points: 150
Do you have a rough-in for a future bath? thats common when they are done RIGHT to leave a vent in the ceiling. It's easy to fix it, drill a hole in the cap (it may have a lot of water in it) drain the water out, cut off cap and glue new on on.
braindead is offline   Reply With Quote
Old 09-18-2010, 06:43 PM   #6
HVAC / Plumbing
turn the water off. cut the PVC just behind the cap & glue another cap on. Watch out.. Unless u drain it. Water will come out
Old 09-18-2010, 06:59 PM   #7
Yes, we do have a rough-in for future bath. That may be it. Is it normal to have water accumulated in the vent?
Thanks.
Old 09-18-2010, 07:05 PM   #8
If it is a vent, the cap may not actually be glued on. The reason for the water may be condensation.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-18-2010, 07:37 PM   #9
Thanks much for the advice. You are exactly right! The cap was not glued. I easily pryed it open. There were a bucket full of clear water. Am I better off leaving the cap off? I assume air flow will prevent future condensation.
Old 09-18-2010, 08:22 PM   #10
HVAC / Plumbing
Where is the condensation line come from or go to ? If it's a condensation line or a vent Why would a vent have a cap on it ??
Old 09-18-2010, 09:15 PM   #11
I really don't know. All I see is a PVC pipe sticking out from the basement ceiling with a cap on. Does anybody know the answer?
Help! majakdragon!
Old 09-18-2010, 09:29 PM   #12
HVAC / Plumbing
Help! majakdragon!
What size line ?
Old 09-18-2010, 10:05 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 436
Sounds like a vent for future plumbing. Bush it down to 3/4" and put a boiler drain on it. When or if you decide to connect to it drain off the water. Or you can cap it on the roof. But be sure no active vents tie onto that line
Old 09-18-2010, 10:34 PM   #14
What size line ?
I just measured it: 2" ID and 2-3/8" OD.
Old 09-18-2010, 10:39 PM   #15
So, the water is from the roof, not from condensation?
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 05:50 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
PEX pipe and sharkbite slowing water flow? Snav Plumbing 1 04-09-2010 04:32 PM
