Water Leak From Behind Drywall - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2013, 12:21 AM   #31
Oso954's Avatar
Rewards Points: 1,636
Hate to pile more on, but while the wall is open, you should get someone to look at that electrical.
Looks like you have some SO cord behind the wall. If it is not SO and is the old black romex without ground, it should never have been extended.
One of the white romex cables was run out the front of the JB and has been pinched by the cover plate.
I can't count the wires but believe the JB is overfilled.
Oso954 is offline   Reply With Quote
Old 07-03-2013, 11:47 AM   #32
t60
Rewards Points: 125
I don't mind, thank you for pointing that out. It's old black romex without ground. I will see if the dishwasher cord is long enough to connect, but it's likely I'll have to buy a longer cord for it so that it can be plugged in prior to pushing it into the cabinet area.
I am also going to replace the outlet with a GFI.
t60 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Mysterious Water Leak Georgia2010 Plumbing 5 12-23-2010 10:02 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
