Water Leak Around Septic Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2008, 09:37 AM   #1
water leak around septic pipe
During very wet times I have water leaking into the basement around the septic pipe. I plan on digging below the pipe and running drain tile away from the house but also want to re seal the pipe. Do I need to remove the current sealer. And what is the best product and way to seal around the pvc pipe
gvanhoven is offline   Reply With Quote
Old 04-12-2008, 10:23 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro, just a long-time DIYer, and I'm sure that there are other products, but I would use black plastic roofing cement. It will seal in the rain, and remains a bit flexible.
However, it is a very sticky mess to put on. Use throw-away rubber gloves, old clothes and flat sticks (paint stirrers work) to smear it on.
It will definitely seal a leak.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 04-13-2008, 10:29 PM   #3
Registered User
Termite's Avatar
I'd suggest leaving the roofing products for the roofing projects.
Remove the existing sealer and clean the concrete around it to the best of your ability.
Get yourself a product called hydraulic cement. Hydroplug is a common brand. It comes in small tubs and you can get it at most good building centers/hardware stores. Use your fingers and a putty knife to pack it around the pipe, working to fill the annular space between the pipe and the wall as deep as you can. When hydraulic cement dries, it doesn't shrink at all like regular concrete does. So, it is great for sealing out pesky leaks. It is what we require on all new homes.
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
