Water Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2012, 02:11 PM   #1
water leak
I have a hot water line leak under my house slab foundation any reconmendatiions?
Alfee is offline   Reply With Quote
Old 04-26-2012, 03:06 PM   #2
Homerepairguy's Avatar
Rewards Points: 998
Don't break the slab and replace the water lines using PEX above the slab. That's what I did.
HRG
Homerepairguy is offline   Reply With Quote
Old 04-26-2012, 05:14 PM   #3
Rewards Points: 13,446
It was common years ago to run copper or steel lines under the slab. There all going to leak at some point.
Not what you wanted to hear but that's just the way it is.
Old 04-26-2012, 08:45 PM   #4
Rewards Points: 582
replace the line above slab..pex or copper....
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 11:36 AM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 09:06 PM
No water in house dls6w4 Plumbing 10 02-12-2011 06:45 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Water Leak swoop Plumbing 2 01-14-2010 06:02 PM
