Old 11-16-2008, 12:26 PM   #1
water knob of fucet will not turn water off
please help
99jasons is offline   Reply With Quote
Old 11-16-2008, 01:57 PM   #2
Hopefully,you have valves under the fixture that you can turn off the water supply. If it is a single handle faucet, it probably has a cartridge inside it with bad "O" rings. If it has two separate handles, it may have washers on the bottom of the stem that have deteriorated and need replaced. Let us know which type you have for better info to fix it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-18-2008, 01:26 AM   #3
I noticed your pic on plumbingzone. just thought that you may not know that the two flat head screws on either side of your valve are actually integral valves and alot are just quarter turn so the slot should be horizontal. I saw that the left side "hot" was vertical. give that a try, may help ya.
Juice is offline   Reply With Quote
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 08:38 AM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
