Water Keeps Running - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2011, 08:47 AM   #1
water keeps running
The tube to fill the tank is constantly running and causing my toilet to partially flush itself when there's too much water. It's raising my water bill. How do you fix it?
HelpMePlz9727 is offline   Reply With Quote
Old 09-08-2011, 08:52 AM   #2
Check your flapper to see if it has any debris underneath. If it does not seat properly, then the tank will constantly refill.
VIPlumber is offline   Reply With Quote
Old 09-08-2011, 08:54 AM   #3
Experienced
Jackofall1's Avatar
Hello Helpme and welcome to the best darn DIY"r site on the web.
Sounds like it is time to replace the filler tube and valve, these are available at any hardware or big box store and cost under $20. The instruction included in the box will help you with the replacement.
Mark
Old 09-08-2011, 10:11 AM   #4
I cleaned the flap. I didn't notice any debris but the water stopped running. If it starts doing it again I'll replace the filler tube and valve. Thank you!
Old 09-08-2011, 11:39 AM   #5
Just call me Andrew
Rewards Points: 1,020
If the problem was the flapper....then replace the flapper.
Andrew
secutanudu is offline   Reply With Quote
Old 09-08-2011, 12:02 PM   #6
I'm glad you solved it. The chain in my toilet is too long so the flapper never goes back correctly. It's a pain to change after every time I flush but it's a way to stop the water from running constantly.
metal is offline   Reply With Quote
Old 09-08-2011, 12:06 PM   #7
Just call me Andrew
Why don't you just shorten the chain?
Andrew
Old 09-08-2011, 04:59 PM   #8
Rewards Points: 1,216
You can tell if the flapper is leaking by putting some dye in the tank and see if it ends up in the toilet after a while. Food Coloring.
COLDIRON is offline   Reply With Quote
Cold water running Amok in Hot pipes genproj Plumbing 2 04-25-2011 06:56 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
