Water Keeps Leaking In Toilet Bowl - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 08:15 AM   #1
water keeps leaking in toilet bowl
I replaced everything in the tank and water still leaks just as much as it did before. I don't know what else to do
dan ashby is offline   Reply With Quote
Old 03-15-2011, 08:40 AM   #2
the Musigician
DangerMouse's Avatar
We need a few more details.... What exactly is leaking where?
Tank leaks into bowl? Bowl leaks onto the floor?
DM
Old 03-15-2011, 08:56 AM   #3
Old 03-15-2011, 09:11 AM   #4
the Musigician
Tiny trickle down the backside ot the bowl?
I'd guess the flapper is still not seated tight enough. Try cleaning under the flapper and be sure the flange is tightened down.
Did you replace everything right down to the ceramic?
On the cheaper one of mine, I added a large nut centered on the flapper to help it seal properly.
The pressure-assisted one never leaked into the bowl.... no flapper!
DM
Old 03-15-2011, 09:23 AM   #5
Tiny trickle down the front of the bowl. I replaced every thing right down to the handle . Checked flapper cleaned it wasn't dirty brand new . Tried changing chain length still same result.
Old 03-15-2011, 09:30 AM   #6
peaked at birth
Make certain to drag your fingernail around the seat of the flapper rim. There may be a cut or debris holding up the flapper there. Doesn't take much.
If you have a primer tube stuck down the overflow, it may be siphoning. The Fluidmaster filler kit comes with a stilt to make sure this doesn't happen. Some make the mistake of using the overflow cap (with the hole in it that came with the toilet) to ram the primer tube down the overflow. Bad thing to do. It goes too far and sets up an perpetual siphon since it is below the water level. Use the stilt to hold the primer tube up over the overflow tube creating an air gap. That's why it's in the kit.
If this wasn't the problem, if the flapper has "ears", and there are intact hinge ears on the base of the overflow tube, use them only, making sure you cut off ALL the pre-molded "O" adapter that comes in between them since it frequently interferes and binds the operation of the flapper when ears are used. You can use sissors... its easy.
Only use the "O" adapter that is meant to slide down the shank of the overflow tube if its ears have broken off at the base. Even then you have to finesse sliding the thing around to get it to work.
analyst is offline   Reply With Quote
Old 03-15-2011, 09:41 AM   #7
Experienced
Jackofall1's Avatar
Hi and welcome Dan, to the best darn DIY'r site on the web.
Just a question, did you clean the flapper seat with scotch brite? Sometimes calcium may build up on the seat allowing an almost unnoticable trickle of water into the bowl.
Mark
Old 03-15-2011, 10:27 AM   #8
I turned off water supply , drained the tank and. The only place there is water is in the bowl and water still trickles from front of bowl can't figure it out
Old 03-15-2011, 10:31 AM   #9
Experienced
Jackofall1's Avatar
With the water off and you are still trickling water, then you have a hairline crack in the bowl, leaking into the cavity and out the drain.
Mark
Old 03-15-2011, 11:13 AM   #10
Thanks for the help,looks like I'm going toilet shopping
Old 03-15-2011, 11:15 AM   #11
Experienced
Jackofall1's Avatar
Ah, you wanted a new one anyway, one of those new thrones, chair height style, complete with 3" flush valve.
Mark
toilet water inlet kept clogging up handyman.wong Plumbing 7 04-12-2011 08:23 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Newer type toilet either leaking water or air in tank drpcken Plumbing 3 04-15-2010 02:30 PM
First time homeowner from MD - Water Leaking from Ceiling under bathroom j_cross Plumbing 2 02-26-2010 11:37 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
