Water Just Trickles - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2011, 08:00 PM   #1
Rewards Points: 14
Water just trickles
Over a period of time the water has slowed to a trickle from my cold water tap in the bathroom sink. The water is fine from the tub faucet and the hot water is fine. I have replaced the cartridge and put a new shut off valve on but still no water. Any ideas? Is there any thing else I might try before calling a plumber?
needtoknow is offline   Reply With Quote
Old 05-25-2011, 08:06 PM   #2
the Musigician
DangerMouse's Avatar
Is there a screw off cap on it? If so, unscrew it and clean the gunk out of the screen.
DM
Old 05-25-2011, 08:14 PM   #3
DIY staff
Rewards Points: 7,174
You shut off valves should be checked---put a feed line on the valves and run some water into a bucket--if bad replace--
Then the faucet itself---sometimes a bit of the cartridge rubber will break off and plug up the valve body --clean out the valve body with sandpaper and flush it out--it that doesn't do it call the plumber--or come back with more questions.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
