Water Hose Nozzle Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2012, 01:18 PM   #1
water hose nozzle leak
I use this water hose.
http://www.sears.com/craftsman-all-r...3&blockType=G3
I also have craftsman nozzles.
http://www.sears.com/shc/s/p_10153_1...0130000P?mv=rr
When I turn the water on the water leaks out from the tip of the nozzles. The washers in the spray nozzles are brand new so I know that's not it.
What else could be causing this?
dinosaur1 is offline   Reply With Quote
Old 06-10-2012, 01:43 PM   #2
Lightfoot's Avatar
Rewards Points: 272
looks like those spray nozzles have a thumbwheel on the back. try backing it off just a turn or two.
Lightfoot is offline   Reply With Quote
Old 06-10-2012, 01:47 PM   #3
I also tried with another fireman nozzle without that and it still leaks.
Old 06-10-2012, 06:26 PM   #4
Rewards Points: 1,492
1. A typical garden hose nozzle does not use a washer at the tip but rather has a metal to metal contact that does not make that good a seal.
2. Are you sure there is not a drip to remind you not to leave the house spigot on for long periods of time with just the nozzle stopping the water and the hose under pressure?
The Following User Says Thank You to AllanJ For This Useful Post:
gregzoll (06-10-2012)
Old 06-10-2012, 06:48 PM   #5
Rewards Points: 6,652
Originally Posted by dinosaur1 View Post
When I turn the water on the water leaks out from the tip of the nozzles. The washers in the spray nozzles are brand new so I know that's not it. What else could be causing this?
Spray nozzles will always leak. Just that they should not be shooting water out. Now of course, I have a good fireman sprayer like you have, but bought at Sam's Club, and have no problem with it leaking water.
Old 06-11-2012, 07:08 AM   #6
Rewards Points: 2,144
I'm having the same problem and it's driving me nuts. A little spray or drip is ok, but I feel I'm wasting water. I'll check back here for future hints.
Startingover is offline   Reply With Quote
Old 06-11-2012, 07:10 AM   #7
When I release the sprayer there's still a small pressure of water coming out of the nozzle.
Old 06-11-2012, 07:21 AM   #8
Do not leave the hose on all the time. If you want to stop water flow to the end of the hose, that the nozzle is hooked up to, you can hook up a ball valve. But personally, if you are using the hose, you are wasting water.
Old 06-11-2012, 07:22 AM   #9
I don't. I only place the hose down while washing my car, watering plants, etc....
Old 06-11-2012, 09:26 AM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Check the pressure on your house.
Journeyman Plumber
Old 06-11-2012, 10:36 AM   #11
I would not worry then.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
kitchen water leak! joregon3597 Plumbing 4 03-16-2012 02:45 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
