Water Holding Tank Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2012, 05:36 PM   #1
Water holding tank leak
Our well water holding tank was toast so we had to replace it. We did the same set up that was used to hook up the old tank, just put in new pipes and fixtures. Now it leaks at several seams even though we've used water weld and clamps. Any suggestions? We've taken it apart twice and it still leaks
Thanks for any help
Kcornell
Kcornell is offline   Reply With Quote
Old 03-24-2012, 06:46 PM   #2
Rewards Points: 1,548
I haven't had any experience with Water Weld or other pipe goop but I have had good luck with Teflon tape. Wrap the pipe threads with four or five layers of white Teflon tape, then screw them together and it should hold water "good".
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 06:43 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
