-   -   Water holding tank leak (http://www.diychatroom.com/f7/water-holding-tank-leak-138113/)
Kcornell 03-24-2012 05:36 PM
Our well water holding tank was toast so we had to replace it. We did the same set up that was used to hook up the old tank, just put in new pipes and fixtures. Now it leaks at several seams even though we've used water weld and clamps. Any suggestions? We've taken it apart twice and it still leaks :(
Thanks for any help
Kcornell
AllanJ 03-24-2012 06:46 PM
I haven't had any experience with Water Weld or other pipe goop but I have had good luck with Teflon tape. Wrap the pipe threads with four or five layers of white Teflon tape, then screw them together and it should hold water "good".
