Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2007, 12:15 AM   #1
Water Heaters
I have a few questions regarding water heaters (home or commercial)
1. Does the TPR valve (temperature pressure relief valve) always have to have a drain (extended leg) attached to it? And if not - must it be piped to the outside?
2. Does the water heater attached to a boiler need earthquake strapping in California?
3. What is the technical term for the spout on the bathtub that spits out the water - is it just a faucet?
Thanks in advance for the answers to these
Cheezhead is offline   Reply With Quote
Old 08-08-2007, 05:09 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, just a long-time DIYer, but my preliminary answers are:
1. Yes, by code, but it does not have to be vented outside. It can be stopped a few inches above a drain pan. Check local Building codes for their specifics.
2. Not sure, but I think so.
3. Spout. The faucet is the faucet body in the wall, etc.
A CA plumber can confirm or correct.
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-08-2007, 07:29 PM   #3
Union HVAC Tech.
Yes, it has to terminate no more than 10" above the floor.
No it doesn't have to be piped outside.
If the water heater is above living space it needs to be in a catch pan which has to be piped to a suitable drain.
Yes
A tub spout (fed from a tub/shower diverter)
No problem
bigMikeB is offline   Reply With Quote
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
Tankless Water Heaters Irishman Plumbing 5 09-11-2007 11:49 PM
Electric tankless water heaters; any experiences? moneymgmt Plumbing 14 05-15-2007 11:36 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
tank less water heaters Dustin07 Plumbing 16 11-15-2005 10:48 PM
