Water Heater, Wrong Connections? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2011, 08:38 PM   #1
HAMP's Avatar
Water Heater, wrong connections?
I recently bought a house. I noticed that the water heater is a 50 gallon tank by 'Richmond'. The tank looks pretty good, and I only say that, because to my surprise, I see a written date on the heater from 12/11/93.
On to my problem, what I noticed about the tank, is that the cold water is connected to the tanks hot water side, and the reverse, the hot water is connected to the cold side.
I don't know if this is connected wrong or maybe it was mislabeled and the installer installed correctly?
like I said, it is a 50gal, and believe me the hot water is hot, but does not last very long.
can someone tell me if it is connected wrong, am I still going to get hot water? Am I paying too much in gas to heat this?
HAMP is offline   Reply With Quote
Old 02-08-2011, 08:47 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If the water starts hot and gets cold quickly, it is plumbed wrong and the incoming cold is mixing with the hot it the top of the tank. Change it.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-08-2011, 09:06 PM   #3
Exactly! If the hot and cold are reversed, you will run out of hot water quickly.
broox is offline   Reply With Quote
Old 02-08-2011, 11:46 PM   #4
HAMP's Avatar
I knew something was wrong, the hot water was not lasting long. It's a 50 gal, but it has felt like a 10-20 gallon tank with how fast the hot water ran out.
It's hard to believe who owned it before me, didn't realize.
Thanks guys for your help.
Old 02-08-2011, 11:48 PM   #5
Richmond = rheem
bbguy5 is offline   Reply With Quote
Old 02-09-2011, 07:44 AM   #6
DIY staff
Rewards Points: 7,174
Good spotting!---
Old 02-09-2011, 11:10 AM   #7
Rewards Points: 338
yep, the only difference is the cold side dip tube runs to the very bottom of the tank and the hot side dip tube is near the top. hot water rises, so if you have the connections reversed you run out of hot water quickly because you are pulling the cooler water from the bottom of the tank.
NitroNate is offline   Reply With Quote
Old 02-09-2011, 11:57 AM   #8
Remodeler
Rewards Points: 316
17 years old........ it might look fine but probably isn't. 50 years ago water heaters were made with thicker tanks, some were even lined and they would last a long time, but they haven't been made like that for many years. The tanks were made thinner to save materials and make heat transfer more efficient. Ten years is about all you can expect out of a basic water heater. It probably has a thick layer of sediment on the bottom insulating the water from the flame and killing the efficiency. I have even seen electric water heaters with the bottom element buried in sediment.
It is living on borrowed time and will likely develop a leak in the not too distant future, probably right after you leave for a couple days. Many times the dip tubes end up broken off after a few years, especially if the water heater or plumbing has been disturbed. If you are going to change the plumbing I would just replace the whole thing now and save the hassle a leak would cause.
iamrfixit is offline   Reply With Quote
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
